Clears the OSPF counters (statistics).
| vlan_name | Specifies a VLAN name. |
| router-identifier | Specifies a router interface number. |
| area-identifier | Specifies an OSPF area. |
| ip-address | Specifies an IP address |
| ip-mask | Specifies a subnet mask. |
| ipNetmask | Specifies IP address / Netmask. |
| system | Specifies the OSPF system counters. |
N/A.
The global command clear counters also clears all OSPF counters. This global command is the equivalent of clear ospf counters for OSPF.
The following command clears the OSPF counters for area 1.1.1.1:
clear ospf counters area 1.1.1.1
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
